Posted by Dan Swanson on April 12, 2008 at 19:17:44 from (63.172.252.161):
I bought the tractor a couple of weeks ago. Steering, clutch, and hydraulics worked fine. Thought I would change all the filters. Changed the trans filter took out a Wix filter and put in a Fleet Guard from the dealer. The transmission oil level was at the low mark before the filter change. I changed the filter, then filled it to the full mark. Started the tractor, the transmission light blinks, along with the Alt. lite. they won't quit. The alt. lite might be a wire problem because it has others too. I pressed in on the clutch several times, I can shift into the gears but if you let out on the clutch it doesn't move. I did however get the tractor to move once then shifted gears and then nothing again. I read the manual on how to purge the air out if there might be some. The tractor has a loader on it so I lifted the front wheels off the ground and turned the steering back and forth several times but it was still very hard to do. I moved the hyd. levers back and forth several times too. I am going to hook a hyd. cylinder up to the hydraulics tommorrow and see if I can get that to work. The PTO, which has it's own pump works fine. Any ideas?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
