Posted by John Franklin on April 10, 2008 at 01:48:35 from (76.106.36.255):
I have a Super A, 6v positive ground, that for now has a dead battery. I think the battery is probably 5 yrs old.
Before removing the generator & regulator to take it to some place to have tested, is there a way to test the system to see which part isn't working. If I put a another working 6v battery on it, is there a procedure I can follow to test the battery.
BTW, when I pull started the tractor, the ammeter shows no charge. In fact, it shows no negative charge either.
A couple years ago I had the VR and generator tested and the generator needs a bushing and it was repaired. Those worked ok then.
I polarized the generator when I installed the new battery years using a jumper wire momentarily shorting the BAT and GEN terminals on the VR. Was that procedure correct?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
