your question has kept my brain busy all afternoon, as there was a memory from 40 yrs ago when the same thing happened on dad's super c. i keep wanting to say that back then, i put the assembly together wrong, and had the 2 pull links aimed 180 degrees off. but there is only 1 way that stuff will go together and still line up with the pin that keeps the assy from turning, right? marv has a possible explanation, but its more likely that the housing edge was planed than the transmission case surface. i'd never heard of someone milling the surface. it would have been cheaper to just get new disks in the first place. it sounds like you could get it going by spacing the housing away from the trans case with a washer. you'd have to put silicone sealer around the housing to keep the crud out if you used washers. let us know what you find.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
