If you think the leak might be coming from the hydraulic belly pump itself - you can remove the drive shaft for it, drain the oil out of it and see what happens.
The lower seal will leak more than the upper - the upper seal should be above the oil level in the transmission (I think).
To get that lower seal out isn't much trouble at all. Remove cotter pins from the pump shaft, slide sleeves toward middle of shaft, rotate shaft until it drops out the bottom (slots will be vertical). Put tractor in 1st gear, lock brakes, use a square bar to turn the drive slot counter-clockwise to unscrew it from the shaft.
Remove 3 bolts and the seal and retainer should pop right off.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
