Most likely a broken tooth on a gear in the range transmission. In high range the speed transmission output shaft is coupled to the pinion shaft in the rear end so no power is transmitted through any of the range transmission gears. You would most likely be able to see the problem if you remove the cover on the left side of the rear frame just in front of the brakes. Any repair involving replacing any of those gears means a complete disassembly of the rear frame. The differential has to be removed before you can take out the pinion shaft.
Flat rate for range transmission overhaul is 15.7 hours without a cab. Most likely there will be some final drive bearings that need replacing so any of that type of work is in addition to the 15.7 hours.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
