Posted by Owen Aaland on April 02, 2008 at 20:25:25 from (65.165.246.59):
In Reply to: 1066 won't start posted by rezner on April 02, 2008 at 10:42:09:
The only part the electrical system has in starting your 1066 is to provide fast enough cranking to generate compression enough heat to ignite the diesel. Black smoke at cranking would not be normal but if it is cranking over but not starting you should be getting a whitish gray smoke. There should be a noticeable difference between the shot off and run positions in the amount of smoke. The pump is designed to go to maximum fuel delivery for starting when ever the throttle is not in the shut off position so opening the throttle any more than a little above low idle is not necessary. the maximum fuel delivery is controlled by the presence of engine oil pressure so if it does not start before the oil pressure comes up you need to wait a couple of minutes before trying again.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
