The issue is compression, and this tractor can use all it can get. 11-12 hp is not much. The pistons will make more power. That said, the other issue is we can't tell how high the domes are. There are no valve clearance issues on a flat head engine design. So, the only way to check this is to put a piston on a rod and put it on the crank with the insert. (rings not needed). Place a thin layer of clay over the top of the piston (1/16" thick) then use the old head gasket, and a few head bolts in that cylinder to hold it down pretty well, no need to torque it. Then ---hand--- turn the engine through one revolution. and pull the head. If no marks, good to go. if marks are made, measure the thiscness of clay in the mark. If 1/32" or less, and in one spot, all the pistons need to be evenly machined to clear the 1/16" requirement (usually not much, but evenly to maintain exact wt.) If it rotates and stops hard against something, leave it there, do not force (even by hand) the engine through the TDC position. THis will tell the tale. Good luck, JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
