Here's a backside view of a switch as on your B. The field resistor is the wirewound unit at the bottom. Seems to me the correct resistance is 3 or 4 ohms - however I'm only going from memory here...
However if it were mine I'd replace the cutout relay with a voltage regulator. The V/R will do a much better job of maintaining the battery, and it will eliminate the need for the field resistor.
I believe the fuse is an SFE 10 (glass tube type, 10 amp). However later letter series and Supers used an SFE 20 (20 amp) fuse - that's what I recommend.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
