Posted by Mike CA on March 22, 2008 at 20:28:23 from (75.31.175.251):
I asked a question a while back about how I can wire my '44 H without the VR and the generator in the loop, just so I can get it running. Here is what Bob M said:
Bob M said: To wire the ignition, simply run a wire from the ammeter terminal that's NOT connected to the batterr. Run this wire to either terminal on the ignition switch. Run a 2nd wire from the other ign switch terminal to the coil primary terminal that's NOT connected to the distributor. That's it! As long as you've got a charged battery the tractor can now be started and run.
I looked at his diagram for the 6v system with a cutout relay and distributor. But it's confusing me.
I'll tell you how I think I'm supposed to wire this, and you tell me if I'm right or wrong, and what to correct:
Positive battery cable to ground.
Negative battery cable directly to the starter.
A 10 gauge wire from the starter to the starter button.
A 10 gauge wire from the other terminal of the starter button to the ammeter.
A 10 guage wire from the ammeter to the pull on/push off switch.
A 14 gauge wire from the pull on/push off switch to the ignition coil.
A 14 gauge wire from the ignition coil to the distributer.
That doesn't seem right to me because I've seen battery cables run directly up to the starter button. But I don't really see that on the wiring diagram, which is why I'm confused.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
