Posted by Dan Bear Kelley on March 16, 2008 at 11:51:36 from (206.53.20.159):
Does anyone know at what S/N International changed the front cover bolting patterns for the distributor adapter? Hmmm. Maybe I should elaborate a little more. I've got a 1951 M:
I've heard that for very late M's, a SM live hydraulic pump will bolt right up.
I've heard that for early M's, a SM live hydraulic pump will NOT bolt up.
So, at what S/N did International make the change?
I've heard that it's easy to fill the old hole, and redrill and tap a new hole, to put a SM pump on an earlier M.
I've heard that the best course of action is to replace the front plate to get the SM bolt pattern on an M.
(Opinion) Is the first option really as cheesy as it sounds?
I've heard that a specially hardened cam gear is needed for the SM pump, so as not to strip the timing gears.
I've heard of people going for years with the old (less hardened) cam gear without problems. (Probably not in my case with a front loader)
I've heard that the newer hardened gear was actually in later M's after a specific S/N.
So, at what S/N did International make the change to the cam gear?
Does that seem to cover all the bases? I know I'm forgetting something.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
