Posted by bc on February 28, 2008 at 11:25:58 from (75.27.227.202):
Hi, I've got the 2606 brakes that had the adjusting ball tightened all the way up and they still didn't bite. Then I backed the ball off and stuck in about an inch worth of washers to get brakes. I took one side apart a posted a while back about it.
The old disks did not appear to be very worn. They were 7/16" thick and still had about 1/16" grooves on each side of both discs. The metal plate surfaces looked good with just some minor rust that I can sand off. The plates expand ok and the ball bearings inside look ok. The springs hold the plates tight together.
I inquired of the thickness of new brake discs and they are only a 1/2" thick which isn't enough difference to take up all the adjustment. My question is why did the brake adjusting ball loose all of its adjustment and need a spacer to work? The adjusting rod will only pull so far.
The only other thing I just thought of, but won't know till I look, is that the brake pedals on the shaft is missing a woodruff key or something but I believe only the left brake uses the shaft but the right brake has the same problem and the right brake is a direct pull on the adjusting rod so that can't be it.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
