Posted by james3504 on February 25, 2008 at 17:29:25 from (70.109.15.32):
Got the tractor all back together. Trans shifts well w/ engine not running. I adjusted the clutch and ta by the book. 1" freeplay on clutch, when ya start tractor in neutral, clutch is disengaged as it should be, but when you try to shift into first it just grinds. I then adjusted it to the end of the rod in slow increments at a time. My results never changed, still grinding. I even used a cheat rod to make it longer, and my results were still the same except the clutch pedal bottomed out. I know this because from looking the inspection plate the three p.plate fingers were against the plate housing at their max. The only thing that I can think of is the flywheel friction surface will have to be machined to let the p.plate release. I"m I correct or not any suggestions would be great before I split again. Thanks
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
