Posted by Bob on February 24, 2008 at 23:01:57 from (69.178.229.154):
In Reply to: Re: Super A Wiring ???? posted by P and R Pete on February 24, 2008 at 14:10:45:
Pete,
When doing a conversion to an alternator, the output wire from the alternator can be connected to the wire FORMERLY connected to the "BATT" terminal on the old voltage regulator that was used with the generator. The actual old voltage regulator is NOT used.
A "3-wire" alternator will begin to charge at lower RPM's than a "one-wire" alternator. SOME "one-wire" alternators are more prone to slowly discharge the battery during periods of non-use than a standard "3-wire" alternator. "3-wire alternators are generally CHEAPER than the "one-wire" units. (I have used MANY $10 "recycled units in old tractor conversions.) The alternators were designed and sold by GM as "3-wire" units. The one-wire units are an aftermarket invention to make it "easy" for electrically-challenged folks to get a system up and running, with some tradeoffs.
The diode has NOTHING to do what what's in the coil, or it's resistance.
It is to prevent the engine from continuing to run when the ignition switch is turned "off", AND to prevent damage to the alternator's internal components. You need to use a diode, OR an "idiot light" OR a resistor (about 10 Ohms, 10 Watts) in the lead to the #1 "excite" terminal on the alternator. Any ONE of those three options will work, and work equally well.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
