Given Ricks number for offset, if the surface was not milled and is foundto be close to 1.406 + or - .005", the clutch should work fine. If the wear, or machine work were only on the friction surface and not the mounting edge, the lever movement you observed would have been greater. Clutch disks wear thinner, so does t both the surfaces of the flywheel and PP that touch it. eventually allowing the pedal no free travel unless adjusted. The pieces that wear in the other direction (increasing the freeplay) include the fingers that touch the throwout bearing, The throwout bearing, the pivot points of the clutch relief shaft, the clevice and link pins that operate the Throwout system, and the pedal bushings. If these systems ake kept lubed, the pedal will work toward no freeplay, if not the whole system can wear such that the freeplay seems to stay the same. I hope this explanation helps take the mystery out of it. JimN
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
