The plow should be level with the furrow wheel in the furrow. If there has been a lot of welding etc on the land axle, you may have a problem. I suspect that the axle was heated to straighten at some point. If so, the metal hardness and rigidity has been damaged. If you can replace the weak axle you will do better. If it is possible to heat and quench the axle several times, the siffness may be regained, however it would have to be removed from the plow. You have to heat it cherry red and quench it quickly in water to restore hardness (several times). As you can see, this is not something you can do with a torch. This is a machine shop job. Heating the steel and then alowing it to air cool with certainly cause soft steel to form.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
