The issue is probably the lack of vacuum when cranking (rings) that reduces the flow of intake through the carb enough to make it difficult to start. If the rings are worn, the best tactic is to replace the cylinder sleeves and pistons, check the crank for size and put in new bearings. The sleeves are wet, which means easy enough to do as a first time project. We can help. Another issue might be a vacuum leak, but less likely. If the rings are just stuck, Pulling the spark plugs, and filling the chambers with about a half cup of auto trans fluid (putting the plugs back in loose) for two weeks, then (removing the plugs) cranking it to blow excess out the spark plug holes. This can free up stuck rings, costs $2 and two weeks. If it doesnt help with the issue, I wager it will take the rebuild (about 600 when all is said and done, doing the work yourself) A vacuum chack simple to make is to hold your palm over the air intake on the carb (hose off) and have some one crank it (safe out of gear brakes locked etc.) if it pulls in on your hand massively, it may be OK in the vacuum department. Keep us informed, JimN
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
