The points are eroded by the electrical arc that occurs each time they open, thats why you found a large gap. Might have been better to replace points and condenser, but it sounds like you're happy with the way its running, so they probably have a little life left. It sounds like you must have removed the distributor. When reinstalling one, all you need to do to is get it timed close enough for the engine to start and run, but you really must check the timing at full throttle with a timing light, because the degree of advance at full throttle is the most critical setting. It's been awhile since I've had anything to do with a 340, but I think the flywheel has degree marks. If so, there should be a cover on the side of the clutch housing you can remove and a timing pionter underneath. Get yourself a I&T manual, find out how many degrees it should be advanced at full speed, locate that mark on the flywheel, and mark it with a white marker so it will show up under a timing light (liquid paper pens work great for this).
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
