Posted by Steve_Md on February 11, 2008 at 04:39:51 from (158.12.18.34):
I am putting this question out for consideration in hopes of an explanation: I installed the mag on a Farmall B and did the initial timing using the mark on the inside bell housing and mark on the flywheel. Using the hand crank, I verified the timing was set correctly, by rotating the motor slowly in the clockwise direction until the mag's click was heard. The next step was to verify the timing was set correctly by using an induction timing light on number 1 or number 4 (in this case, either one works to verify) cylinder plug wire. With the engine idling, I spotted the caulked flywheel mark near the 8 o'clock position, looking forward in the inspection opening at the flywheel, instead of where it should be at the 6 o'clock position. Why is it that the mark is approximately 50-60 degrees off location using the timing light and yet the static timing is correct? Am I overlooking something here?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
