Posted by Up North Louie on February 10, 2008 at 19:22:30 from (65.73.75.68):
In Reply to: 560 power steering posted by 560 in KS on February 10, 2008 at 17:53:00:
A few thoughts, some of them unpleasant.
Start by making sure you have the 16 gallons of HyTran you are supposed to have. There's a square 9/16 plug on the left side of the transmission housing to check this. Then check your filter (hydraulic) on the right side behind the hexagonal access plate. Be ready to catch 2-4 quarts of HyTran when you open it up. Sometimes new fluid acts like a solvent and loosens up lots of gunk which clogs up your filter in a New York minute. Your problem sounds similar to the last difficulty I had, and a new filter did the trick.
After that, search this forum, because this subject on this tractor comes up every month or two. There's at least 2 threads I started. There's stuff to go wrong with a worm gear near the front bolster and a little valve that works with it. I still don't understand this. Fortunately, it has yet to be my problem.
The hydraulic and power steering pumps are behind a rectangular access plate on the left side of the transmission. Get a pressure gauge and hook it up, see what you're getting. There is a 12 gpm pump, and a 17 gpm pump; which one depends on the year of your tractor. The power steering pump piggybacks on to the regular hydraulic pump. I replaced both of these and the shaft that drives them last spring. It was painfully expensive. Nobody seems to rebuild them around where I live. But I got my PS back.
That wasn't the end of it. I had the valve banks rebuilt, too.
What sucks is that I couldn't be there to watch/help do the work because of my stupid day job. It is my prayer that the new job I have applied for comes through, as the scheduling on that one will be a lot more flexible. And a lot less time on the road. Not to mention nicer people and better work...
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
