George, the resistor you need is for the alternators excitation circuit and as Jim noted IS NOT the same as any ignition coil ballast...... From some GM literature I read once I highly recommend a current limiting safety resistor in the alternators excitation circuit versus no resistance at all and I use a 10 ohm..... While the power rating in watt isnt requited to be as big, if you buy like a 5 to 10 watt 10 ohm resistor they have bigger easier to wire leads n are more heavy n rugged then a smaller watts power rated unit.
The 10 ohms 5 or 10 watt resistior wires in series after the voltage source (ignition switch usually) and before the alternators lil No. 1 side excitation terminal.
An idiot light is probably even way more resistance then a 10 ohm current limiting safety resistor I use n the alternator still receives sufficient excitaion. I dont usually even use a diode since the 10 ohms usually prevents ignition run on which the diode can be used to prevent.
Ive seen em used with NO resistor or diode n they still worked fine but as a conservative I prefer at least somne degree of current limiting protection in the excitation circuit be it a 10 ohm or an idiot light or a diode which ahs a 0.6 voltage drop across it.
Get a 10 ohm 10 watt resistoir from Rat Shack is my advice.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
