Posted by Christine Walls on January 28, 2008 at 11:29:08 from (69.19.14.15):
Hello all, I have a Farmall Super H. This summer it started behaving badly, it was running poorly and leaking gas from the bottom of the carb. I put a kit in it and it seemed to help for a while with the leaking, but the tractor did not have its former power and it started leaking again. Then it got to the point where it would not start at all. I've had the carb off and on maybe 5 or six times, adjusting the float and drop levels, and it's still leaking.I think what's going on is the little rod that holds the float is coming out allowing the needle to fall out. I have tried crimping it, but it doesn't work. Has anyone else had this problem and figured out a solution? Also, are the Super H carbs different from standard Hs? I have the books on this tractor and the carbs shown look different than mine. Any help will be most appreciated. Thanks, Chris
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
