Posted by Daniel H. on January 27, 2008 at 13:46:40 from (66.226.34.159):
In Reply to: 46 super a posted by John OCD on January 27, 2008 at 13:23:05:
Changing them isn't hard, it's getting to them that's the pain. You will have to securely support the rear of the tractor, wedge the front end and remove the final drives. While your in there, plan on changing the differential shaft seals, or your new brakes will be coated with oil before long. I would pick up an I&T manual (IH-8 ) from Tractor Supply or Binder Books, because it has exploded drawings. Also, it is very common for the right brake mounting casting to be worn out, which lets the pedal flop sideways and not pull on the brake. OEM Tractor Parts has new castings, or you can have yours bored out and brass bushing pressed into it by a local machine shop. The shaft may need repair as well. Be careful with the rear end off the ground, I would do one side at a time. See the wedges below Figure 51 A.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
