Posted by Mark (PA) on January 26, 2008 at 07:50:21 from (207.255.63.186):
Hello all,
I have a question about a Super A engine. I use my Super A with rear mounted 7' sickle bar to cut about 30 - 40 acres of hay last year. It worked very well with the exception of the points going bad. I replaced them and we were off and running again.
The question I had was when I was mowing I noticed at times that there was either exhaust or maybe oil coming out the oil filler / breather. This happened most often when I was mowing UP a hill, or when the engine was under heavy usage maybe. when on the flat ground and down hill I didn't notice it at all or not much at all if any.
I am wondering what is causing that? Is that normal?
I did a compression test on it at the beginning of last year and what I found was approx 90 psi average with one cylinder a bit higher. I can repeat the testing again I guess this spring to see how they are comparatively.
So I didn't know really if that exhaust or oil coming out that breather is something I should be worried about? Does the engine maybe need some rebuilding or work?
I plan on using it again this year to mow hay so I want to make sure (to the best I can) that it'll run well all season. I probably will be cutting closer to 60 or 70 acres this year with it all total.
Any suggestions on what I should check or do (if anything) please let me know.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
