With the engine warmed up try this: remove all spark plugs and re-do the compression test only squirt some clean engine oil in each cylinder first, crank the engine to spread the oil around, and repeat the compression test. You did have the throttle wide open to allow maximum air entry, didn't you? If all readings increase 10-2- pounds, this indicates worn rings. With all readings even, the valves are not suspect. To get a more accurate result, purchase a leak-down tester. It will tell you exactly how much leakage your engine has and where it is leaking.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
