Posted by Idaho Boy on January 24, 2008 at 17:20:10 from (63.239.240.1):
Gentlemen, I have a SMTA with, I am quite certain, an original IH live hydraulic pump. I am installing a Northern Tool # 2040 (Prince) flow control valve for a power steering motor. The instruction sheet says that there MUST be a relief on the INLET side of that flow control valve. The valve is rated to 3000 psi. Is the IH live pump rated in excess of 3000 psi?
I have purchased a pressure relief valve #2044(Prince), but had planned on installing it downstream of the flow control valve before the the power steering motor. If I install a pressure relief upstream of the flow control valve as instructed and reduce the pressure to 1000 -1200 for the ps motor, the bypass pressure will also be reduced, correct?
Also, how can I tell if my live pump is indeed an IH pump? What kind of pressure does this pump put out if in good condition? I've not put a pressure gauge in line to check the pressure. How much pressure does a remote cylinder need to perform to it's max? Does that vary by cylinder?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
