Do you have any end play in the steering wheel shaft?? Any end play will result in loose steering. You state the bearing at the end behind the hex plug on the steering grear is good. However, are you sure the plug is in tight. The hex nut on the end of the shaft that holds the bearing in place must tightly clamp the inner race of the bearing against the shoulder on the shaft. The big hex plug must clamp the outer race tightly against the steering box. I found it necessary on occasion to install a machine washer behind the plug to get it to clamp the outer race. If you put a washer there, make sure it does not contact anything but the outer race.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
