Well, I've taken the carb apart again, I had the float in correctly as there is only one way it will work.
I will still order a new seat and needle for it. The cut up shut off solenoid and adjusting needle valve will work but I will order a new adjusting needle for it.
However, I am still trying to determine which carb it is. Can someone confirm whether a IH 1 3/8" carb will have a 1 3/8" diameter in the throttle butterfly throat? The parts guy that looked at it on Sat. called it an 1 1/4" but he didn't measure it. The carb seems to match the carbs found under the 706 and 806 models. I measured the throat diameter inside the carb and it is a 1/32 under 1 1/2"
I now suspect I have a 2606 with a gas engine. The parts book states it has a diesel but there is an occasional mention of gas parts that suggests to me a limited number of 2606's were made with gas engines. I just wish I could match up the engine casting number with something to tell me what size it is. A C-263 maybe?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
