Posted by Stan(VA). on December 23, 2007 at 12:11:05 from (4.248.37.46):
In Reply to: Re: Farmall 240 engine posted by MN Scott on December 22, 2007 at 15:47:45:
The back might bolt right in, but the front is a different matter. Make sure you get the motor complete, as you will need to bring over all the new style accessories with the motor, then find a 140 donor for the radiator and it's bracket. Match the air cleaner to which manifold you use.
I've done this swap before, it's possible; but no the motors are not a direct swap. The blocks are different which requires a new water pump and pulley arrangement. Everything is driven from a single thin belt vs the two belts used on the Super C. The upper water neck and the radiator inlet are also at different angles which requires the 140 radiator replacement. Stan(VA).
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
