CWB, on 6 volt systems I recomemend the biggest heaviest highest rated battery that physically fits in the mount and nuttin less then 0 better yet 00 gauge cables as mentioned below. A shop can give the battery a load test at no charge usually. If the ground is to any thin wimpy rusted sheet metal try it to a good frame bolt. Another place a problem can develop is a starter switch or solenoid. Depending on what type it is on some you can by pass jump around them n see if she cranks better then indicating a burned/carboned/resistive switch or solenoid. On tractors with the saddle mount push starter switches they can be removed and you may find the starter post is badly burned n pitted or the switch contatcs are burned/carboned/resistive.
I suggest to be safe to remove n clean n wire brush each n every battery n starter n ground n switch conenction,,,,,,,have the battery load tested n her fully charged,,,,,,,,all clean cables n conenctions n grounds,,,,,,,,big heavy battery with 00 gauge cables,,,,,,switch or solenoid test,,,,,,,,,, n then if shes till a slow cranker I suspect a starter problem like bushings or armature or a brush problem.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
