Loosen the oil pressure connector at the engine. If you start it briefly and oil comes out of the fitting from pressure, then AndrewZ may be perfectly correct. If none comes out within about 15 seconds, I would probably pull the oil pan and check the pump and drive gear. There are many posts on oil pump repair in the "search for" archives above. If it does send oil out the fitting when it is loose, retighten it and use a hair dryer on the tube to the gauge. Loosen the fitting at the gauge and run the engine when it is it is warm, the moisture will be pushed out. Re tighten and see if it makes pressure. If not, try a good known gauge at the block fitting to assure your pressure. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
