Jim has given ya good advice as theres no substitute for cubic inches n compression so I will just toss out a few more things to save a few precious HP in case youre not gonna go to those measures. GET RID OF HORSEPOWER ROBBERS
1) A fan eats up HP and since the pull is so short you can likely get by with less air flow through the radiator. Things like straightening the blades and balancing the fan can gain some HP to the wheels.
2) A generator takes up HP and if by using a simple toggle switch you disable it during the short pull you save some HP. The potential spark gap energy isnt gonna be reduced much regardless if the battery voltage is only 12.6 versus 13 to 14 during the pull
3) Water pumps take HP. Ive seen dudes use 12 volt electric pumps to use stored batetry energy during the pull instead of using up HP from the engine.
4) Heavy oil eats up HP in the form of heat n friction. Im talkin more about gear n tranny oil here n if its ONLY for pulling LIGHTEN IT UP.
5) Of course theres no need to waste any HP driving any more gears then necessary so disable any hydraulics or PTO as you can
6) Have her tuned up perfect ignition wise and the carb set rich enough for when she pulls down hard n heavy.
7) Cooler air is more dense so try n plumb the air intake away from heat best you can and avoid any unnecessary inlet air restrictions.
8) BALANCE have her set so under a hard pull the front wheel just barely float off the ground so alllllllll weight is on the rears. Of course, that has to change with track conditions and needs to be adjustable.
9) Have the rears set in close and drawbar height as high as permissible plus close to the tractor not wayyyyyyyyyyy back. High n close,,,,,,,
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
