Being a straight bevel gear makes setting up this fit much easier. The service manual for the H emphasizes two things: backlash and alignment at the back (wide) edges of the tooth contact area. There are paragraphs about "heel" and "toe" but not being hypoid, you can't really do a lot about it. When putting my '51 H back together, a shim was taken from under the right side and put under the left side cage to bring down the backlash. Since the ring gear was moved perpendicular to the pinion gear, contact points weren't affected at either edge of the teeth. If you decide to measure the backlash, be sure to take all of the slack out of the differential carrier assembly to the right because load forces will always press in that direction.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
