The easiest solution is to compress the clutch pressure plate using three of the 6 mounting bolts. remove every other one, and put them into the clutch cover (pretty obvious visible spot) As they are installed and tightened (not all at once, do it in stages) the fingers will move forward allowing additional wiggle room in the shaft. It is still a case of geometry and juggling. If you try to put it together wrong, it will be very frustrating. Look at the diagram and it will go in, no split is needed. To replace the clutch yes, to put in the shaft no. The holes are remnant access holes for a belly pump Liftall system your tractor may have had at one time, or possibly never had. The space can often be used for a hydraulic reservoir if one is fabricated to fit the space and hole location. I hope this helps. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
