Posted by glennster on November 27, 2007 at 08:44:20 from (76.224.26.7):
In Reply to: Farmall Crankshaft posted by WonderingAl on November 27, 2007 at 07:00:58:
figgure 30-40 dollars to cut the flywheel. the starter gear is easy to change if you have access to a cutting torch, turn the flywheel face down, gently heat the gear in 3-4 spots around the ring, tap it and it will fall off. you can get a new ring from this site, or if yours isnt wore more than half way thru the teeth, you can flip the gear over and put it on the other way. generally a crank cut will run 100 to 300, depending on how bad. have them check the cam lobes and bearing surface. i would have the engine block hot tanked to clean it all up and new cam bearings installed. the machine shop can do all that for you.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
