Hi Vito, I think sealing up the belly would be more trouble than it is worth. When I put live hyd. on I chose to use the transmission and rear end as a resivoir. That was over 30 years ago, after several thousand hours I still think it is by far the best. I draw from the drain plug in the rear, the first filter is a 1 inch pipe cross, use plastic plugs in the side holes they have a hollow center in which there is a cow magnet suspended. Then a suction strainer and also a 10 micron filter in the return line which goes to the oil check plug on the left side. There I put a street ell and then a tee, use the side hole with a plug as the oil check. This raises the oil level at least 2 inchs, with Hy-tran I now I have gotten longer bearing life and have no problem with a bearing turning in the casting like I had before. The pump I got from TSC for about 70 bucks still works like new. I did the WD9 the same way and it has worked very well too. Good luck, Chuck
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
