When Liftalls get into the prime of life (working well, but many hours)the release of the lever seems to be jerky under high load. Two solutions come to mind but are not tested. One easy, one hard. EASY: stiffen up the rod controlling the lever. The rod flexes enough to allow springing in the length of the rod and this seems to be a marginal way to be delicate in control the lever. It is ugly, but a test of the idea might be to use a Vicegrip and "clamp" a 1/2" diameter rod near the lever end of the regular control rod and use that to "parallel" the normal rod to see if better control results from a stiffer rod. HARD: within the Liftall there is a spool valve the lip on the spool that closes off the return of fluid to the resevoir could be modified with a Dremel grinder on one edge to allow valve movement to open a smaller channel as it begins to relieve pressure. Unless you are pretty sure of what you are doing with spool valves/hydraulics, this might be a bad idea. (consulting a good older hydraulic expert to assist might be good as well) JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
