There are several possible problems. A 51 super C has (from the factory) a 6volt positive ground system. with a generator, voltage regulastor, amp gauge, and a starter switch using a rod to mechanically connect the contacts inside (at the starter). If yours has had an alternator put on it from a automotive/truck application, it will (most likely be 12 volt negative ground.
If you put the battery in incorrectly, with either system, turn it around.
If the sparks were serious and you left it connected, things may be toasted a bit and need some diagnosis. The ignition switch can go bad, but it usually fails by not working, not by staying on. THe sparks fron the ignition being on would not make you excited they would be mild little sparks. Let us know if you have an alternator retrofit, or stock system, or what. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
