Definitaly a distillate tractor... I'll bet the hood has an extra hole in it on the mag/distributor side...
No particular benifit to having this set up, the manifold is most likely already set to the "cold" position for running on gasoline, since it has been many, many years since kero or distillate was cheaper than gasoline.
The drawback is that, even in the "cold" position, the manifold will be hotter than a gasoline manifold and you will lose a little bit of power from that (not much, though). Also, the head is most likely the low compression casting, which also costs some power (unless high compression pistons have been fitted). My head casting is 8776D which is one of the distillate numbers. Even with step-head pistons my compression is lower than if I would have had a gasoline head, but the power difference isn't that much.
As far as carb settings, you basically develop a feel for it. The idle screw should be set so it idles nicely and the high speed should be set just so that it doesn't throw any black smoke. Right or wrong, that's how I've always set mine... in light pulling situations you can also lean out the high speed jet just so it doesn't stumble when you throttle up.
A manual from binderbooks dot com would be an excellent investment.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
