Second is a sliding straight cut gear with a matching gear on the counter shaft. When put in gear, the teeth mesh across their width. For it to pop out, four things may be found to be either the whole cause, or partial contributor. 1) the second third shifter fork could be bent and not getting it into 2nd all the way. (pull cover to fix) 2) The detent ball and spring on the 2/3 shift rail may be frozen, weak, broken. Pull cover to fix 3) the teeth may be ground off to a bevel allowing it to want to come out of gear. Replace gears on output shaft, and lay shaft. Pull cover, pump, and disassemble trans to the basic case. 4) bearings may be out of the 2/3 slider allowing it to be forced crooked on the shaft. Same as #3
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
