Sorry to hear of your problem; the bull gear needs to be removed to replace the bull pinion casting. Band brake tips-H & M Remove the pins holding the brake adjuster to the pedal & actuating lever. Loosen & lube them. Remove the cap screws holding the brake housing; wiggle it & they should come off. Note or draw a diagram of how the brake band is attached to the cam. Turn the housing over, shake, tap or whatever to get the 2 pins out. If you remove the outer lever & half-moon key the whole thing comes out. Replace the band & be sure the brake cam pivot shaft works freely in the cover. Oil or grease the pivot the area well and let the excess drip off before installing the new bands. Remove the brake drum; do not try to remove the bolted-on housing containing the seal. The bull gear has to be removed first to get the housing off. Using punches, chisels, etc. collapse the old seal inward, if original; it is difficult but will succumb to persistent efforts. Replace with 2 seals per side and place some chassis grease in-between them to protect the outer one from drying out. Polish the sealing surface and re-assemble. Place a small amount of grease in the hole where the brake pivot goes into the transmission housing. After installing the bands & getting the pedal free-play to about 1", apply the brakes firmly, lock them in place and adjust the setscrew on the bottom side of the cover. (helps to loosen any adjustable parts BEFORE re-assembly) Loosen the jam nut, turn the set screw in until it touches the brake band, back out 1/2 turn & lock the jam nut. This helps prevent the brake band from dragging, premature wear, and overheating.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
