Posted by K.B.-826 on October 02, 2007 at 19:38:56 from (66.188.196.198):
In Reply to: Paulson Loader Repair posted by John in wisconsin on October 02, 2007 at 18:17:32:
I'm not sure exactly what your cylinders look like, but in general, cylinders are pretty easy to rebuild. First, you'll need to get it apart. This is done by seperating the guide at the rod end of the barrel from the barrel. There are several means by which the guide is held into the barrel. Some thread in. Some use flanged end caps with four threaded rods running from one end of the cylinder to the other. Some use two snap rings, one on the outside of the guide which must be removed first, and another one inside the barrel which is accessed by driving the guide inwards a short distance. You'll have to examine your cylinders to see exactly what you've got. Once the guide is free from the barrel, try to pull the rod/piston out of the barrel. This can be tricky sometimes, especially if you've got the type where you had to drive the guide inward to get at the inner snap ring. What I end up doing somtimes is secure the end of the barrel to the legs of a large cherry picker. I then attach the end of the rod to the boom of the cherry picker and jack it up until the cylinder is fully extended and the cherry picker is putting pressure on it. I then strike the guide end of the barrel with a rubber hammer, and it pops apart (watch out for flying parts). Once you get it that far, it should be obvious how to remove the piston from the rod, and which parts from the kit go where. Make sure to check the rods for straightness with a good straightedge, bucket cylinder rods are often bent from abuse/hard use. If the rods have any knicks in them, carefully clean up the sharp edges of the gouge with a sharpening stone or emory cloth. Don't try to remove the whole knick. If the barrels show any damage, they can be cleaned up with a hone, but that may be a little difficult on somthing as long as a loader cylinder.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
