Posted by K.B.-826 on September 24, 2007 at 20:43:24 from (68.115.86.254):
In Reply to: 826 - Fuel pump posted by Bradford on September 24, 2007 at 18:29:25:
Look at the lower arm on the pump. When it is in the full forward position and contacting the stop screw, it is in the "run" position. You'll notice that as the arm is moved to the rear, it contacts a little spring loaded plunger. When it just contacts that plunger, the arm is in the "starting fuel" position. As the arm is moved all the way to the rear and compresses the plunger into it's barrel, it is in the "shut-off" position. Anything in between the "run" and "start" position will decrease the amount of fuel being delivered and will cause the engine to run slower and possibly stall. Start the engine and run at idle. Move the arm quickly by hand to the "start" position. The engine should speed up to about 1900 RPM. This will confirm that it's adjusted and working. It takes a little practice to feel the arm hit the plunger through the cable. Here's the proper procedure for starting- move the throttle lever to the 1/4 throttle position, pull the cable to the start position, crank the engine, and hold the cable in the start position until it is firing steadily enough to stay running, then throw the cable forward. It is also interesting to note that for some reason, these engines get harder to start after a failed attempt.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
