You will for sure need to remove the top cover. Also will need to remove the front yoke and input gear on the front of the transmission. You will want to keep this input gear as a matched set to your shafts input gear.
Also keep all the adjustment shims you get from your donar. You will spend days trying different adjustments to get your transmission to be quite with different shim adjustments. If your keyway is worn and your transmission is not noisey now I would strongly suggest you weld the keyway a little at a time as to not warp or destroy bearings and seals and then grind it to shape with a die grinder. I have a shaft laying in the shed with a good keyway but worn out gears. I wouldn't want to spend the time I have adjusting to get things quite in my F-12 again!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
