Your question is a bit cryptic, but I give this answer. Set the pont gap at .020" on a high point of the distributor cam. Then set the timing at TDC as follows: number 1 piston (closest to radiator) at top on compression, with the pointer at the TDC mark on the crank pulley. Use a 6v (or 12v) test light on the distributor side of the coil. Set the brakes and neutral. Turn on the ignition loosen the distributor at the casting, where it can be rotated a bit. Move the distributor in the direction of rotor rotation until the light goes out,(or if it is out) then rotate the other way until it just comes on. Be careful to have it just come on, no more. This is TDC. (If your manual has it set at the other mark use that as the reference)
To find out if the centrifugal advance is working, a timing light is needed. When running, the timing will proceed farther and farther away from the TDC mark until full advance just before High Idle. If you are pickie, a degree wheel, or degree marks for that pulley size can be applied to the pulley.
The heart of your stalling on a hill might be fuel related, Water in the fuel bowl, or debris in the tank can reduce fuel flow on hills only and be the cause of this grief. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
