Posted by John T on September 14, 2007 at 13:13:48 from (66.244.83.147):
In Reply to: Ammeter wiring posted by Farm130 on September 14, 2007 at 11:15:36:
Farm, To add just a bit to Bobs advice just in case you werent aware, theres usually ONLY ONE wire on what I call the ammeters SUPPLY terminal and thats its hot battery voltage feed usually off the battery/starter where the big ungrounded battery cable attaches to the starter switch or solenoid. Its other LOAD terminal is what wires to the BAT terminal on a Voltge Regulator or Cutout Relay PLUS feeds battery voltage to the lights n ignition. Therefore, theres often ONE wire on the Supply Side and TWO over on its other Load side, so if she registers bass ackwards do the side to side wire swap as Bob told ya.
On some of the older automotive Negative ground system ammeters the labeling convention was + = Supply terminal (to + battery post) and - = Load terminal wired to VR and switches. If such an ammeter was used on Pos ground the - goes to battery and + would feed switches and BAT on VR NO WARRANTY HOWEVER LOL Like Bob noted there may not be any labels at all???
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
