Posted by Janicholson on September 08, 2007 at 16:55:40 from (66.173.50.4):
In Reply to: Farmall WD-6 posted by karsky on September 08, 2007 at 16:47:24:
Several things can make that happen: The ground switch on the manifold that shuts off the mag when in D mode could be disconnected, or broken, or not being moved. The linkages that operate the starting valve might be jambed (If it will not crank fast or at all suspect this) The plugs may be fowled and not sparking. Have you choked the devil out of it to get it to fire? some take extreme choke and rich fuel to run on gas. Is the mag in time? Will it fire on ether in the gas mode (do not try this on the D mode!!) is there a steady stream of fuel to the carb? Good luck, Keep us aware of the progress. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
