Probably the front seal. We have had alot of seals leak on the 400 series engines. The seal can be changed without removing the complete front end. Have to remnove fan and shroud. Remove A.C. compressor if equiped. If early tractor the front damper uses three hole puller late ones two hole. I use a hook type seal puller to remove seal. Put in new seal and wear ring on damper pulley. You will have to use two different lenghts of bolt to pull the damper back on the crankshaft using the retaining washer. Just make sure the crankshaft key is all the way in the groove and the pulley is lined up. Have any problems contact me
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
