Posted by Doc Larry on September 04, 2007 at 05:33:53 from (216.146.101.227):
In Reply to: MD injector pump posted by Doug N on September 03, 2007 at 11:29:50:
Doug,
The transfer or lift pump supplies fuel at low presssure to a master plunger that delivers fuel at much higher pressure to the injectors. What you're describing sounds much more like a problem on the high pressure side, or possibly a timing issue as you mentioned. You definitely should get some smoke under load. I think the timing procedure is given in the owner's manual if you have one. If not, a fairly detailed explanation is on either this site or the Red Power site if you do a search of the archives. Sorry I can't remember which.
Assuming you've done all the filters and checked out the scavenging valve, you may end up having to get the pump checked out. I got lucky and found a good used one, cheap, after buying two that were worn out.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
