I had the same problem with the Liftall pump on my '47 M this spring. The crack in mine was about half way along the high-pressure passageway for the left rear outlet (the one on the pump back plate).
I ended up using carb cleaner to remove the oil residue from that passageway, screwed a plug into the end of it, then mixed up 3 tubes of JB Weld and filled/plugged that passageway completely. I let it cure overnight, re-assembled and installed the pump, it's been working fine with no leaks or problems since. (I only use one hydraulic outlet, so having only two working outlets isn't a problem for me.)
I don't know if just the pump back plate is still available anywhere, but even if it is, I doubt I could get if for the $15 it cost me for the JB Weld. The only whole pumps I could find, including this site, sell for at least $700.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
