Posted by John T on August 28, 2007 at 17:58:35 from (66.244.83.147):
In Reply to: farmall cub starter posted by farmallcollectr on August 28, 2007 at 15:51:57:
Are you jumping it with another 6 volt battery or a 12 volt??? If with another 6 volt your tractor battery may be bad or it might just need a recharge. If you jump a 6 volt starter at 12 volts they usually (unless starter is shot) spin real fast. Id take the battery to an auto parts shop cuz they usually will check n load test it for free then you will have a better handle on if its a battery or starter problem.
Just to make sure I would first remove, clean n wire brush, n reatatch each n every battery n starter n starter switch n ground cable connection cuz if any are bad it can cause poor cranking. Heck you may just need the battery charged and cleaned up cables n connections????
Try the easy simple no cost things first like clean all the cables n connections n charge up the battery and/or have a shop check n load test it. Then if all that fails you may have a starter switch or finally yes a starter problem...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
